Posts: 36 |
I was talking to a Ford mechanic about the SAFC and he said that it wouldnt work on my car because the computer would relearn the changes too quickly for me to benefit from them. Is this true? Its a 96 SE V6 MTX
Posts: 4,292 |
yes,yes,and no...yes it'll work..yes it'll relearn itself,no it wont happen sooooo quickly that you wont see benif'ts...a tiny winnie piece of advice for ya'...dont take what your ford mechanic has to say to seriously...after all,he's a ford tech and not a porsche tech for a reason
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 1,746 |
Originally posted by tour96SeVT: ...after all,he's a ford tech and not a porsche tech for a reason
HAHA!! Quote of the week for sure.
2000 Contour SVT
SF - #542 of 2150
Posts: 36 |
ok well, how long after, say i enrich it for a run on the track will it relearn itself?
Posts: 4,292 |
Originally posted by Titusfighter: ok well, how long after, say i enrich it for a run on the track will it relearn itself?
no you'll have way more time than that....it'll take you a little while just to get it dialed into were you want it....ask demon or warmonger,they'll know
Posts: 1,089 |
99 V6SE Sport ATX
Posts: 7,025 |
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,089 |
ah... ok. thank you. and couldnt you just unplug the battery so the car will reset itself and unlearn what it has learned?
99 V6SE Sport ATX
Posts: 5,810 |
The SAFC is great for tuning full throttle air fuel ratio in small ranges, say 10-15% max. 20% change in fuel is too much to use an SAFC/eManage in my opinion so if you need that much adjustment then don't use it.
As far as learning, if you only use the SAFC to tune the WOT settings then it will work fine and not be 'learned out'. If you try settings at less than WOT then they will be trimmed out a bit or even all the way by the stock computer as the computer will always attempt to get the fuel mixture to what is was programmed to be, up to +/- 25% I think. Anyway, if you are using a hacked maf(bad idea), slightly bigger injectors(less than +/- 15-20% ), or just want to fine tune the WOT fuel mixture then an SAFC will work.
See My Mods
