Posts: 663 |
it doesn't happen everytime but sometimes when I start my car up the coolant light stays on for like 5 or so min. until the engine warms up... I was told that it's prob. just air in the system, and needs to be purged out.... If this is so, how would I purge the air out and/or do I need to do a coolant flush??? I did flush the coolant in October and this problem only started like 2 or 3 weeks ago..
any help/suggestions you guys have is greatly appreciated.
Thanks -Keith
Keith P.
Killed in action-4/27/06
'99 CSVT
#2369/2760-7/28/99
New Recruit-
1998 EO CSVT
# soon to come
Black 106,xxx
Posts: 7,117 |
Add a pint of coolant. That should take care of it.
Posts: 1,788 |
Overfill by 1/2"
See FAQs on MAIN SITE
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 1,074 |
If that doenst work its most likely the sensor like in my car. Its annoying but i dont mind it too much. Too poor and in college to get teh sensor... esp because ford makes you buy the entire coolant tub too.
Brett
The man thinks its best for everyones safty if i dont drive for 6 months
'95 Moonlight Blue Contour (ITS ALIVE AGAIN!)
MODS:
Knauberized,Reverse Indiglo Gauges,LED's,AEM Intake,Rust holes for more power!
Posts: 663 |
Originally posted by TourDeForce: Add a pint of coolant. That should take care of it.
Originally posted by projectSHO89: Overfill by 1/2" See FAQs on MAIN SITE Steve
I'm pretty sure it has nothing to do with the level as it is just above the fill line now, and I have had it go below before, and when that happened the light stayed on.
Keith P.
'99 CSVT
#2369/2760-7/28/99
New Recruit-
1998 EO CSVT
# soon to come
Black 106,xxx
Posts: 6,791 |
Check for holes in the hoses. My upper radiator hose had a pin sized hole and it caused thee EXACT problem you just described.
Posts: 5,143 |
Originally posted by Manch-VegasSVT: Originally posted by TourDeForce: Add a pint of coolant. That should take care of it.
The sensor is faulty on the duratecs, the level needs to be above the full line before the sensor doesnt see that its low.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 344 |
Usually once I get the car moving it jostles around the coolant and hits the sensor and it turns off.
Posts: 4,693 |
Or the level goes up a little as the coolant heats up and expands.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 4,051 |
Originally posted by AliasJerkââ??¢: Originally posted by Manch-VegasSVT: Originally posted by TourDeForce: Add a pint of coolant. That should take care of it.
Faulty? I don't think so. It needs to be just at max or slightly below. If that doesn't work there is other problems.
