#1537454 03/29/06 06:21 PM
Hi,
I am replacing the rear brake shoes and while reassembling, the spring came off the auto adjustment arm. I can't figure out how to reattach the spring. I am hesitant to start taking the other (untouched) brake apart to research and was wondering if anyone can describe - or even better has a picture of how the spring goes on the arm.
1997 Contour
Steve
Semper ubi sub ubi 2004 Ford Ranger 1997 Ford Contour 1988 Honda VT800 Shadow 1980 MG MGB
Since you still have the other side still together, you have the best possible source of info at hand.
Just pull the drum from the other side and compare the two sides.
Keep in mind that the sides will be exact mirror images as you view them.
Steve
Also check autozone.com. They have all the repair manuals online, should have a diagram there.
Scott Mabe I WILL be Phil. 1999 Contour SVT, Tropic Green BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
