This guy who used to work at our shop bought an 87' GN that had 52K on the clock, all original and pretty "ratty" under the hood, heres what he did to go 12.6 @106 mph for $1K in mods:
-cleaned out OE intercooler
-adjustable wastegate, set to 22 psi
-adjustable fuel pressure regulator
-"Muscle" fuel pump
-100 unleaded octane chip (locked up the converter too)
-"OE style 3" downpipe
-Dynamax cat-back
-new coil pack/plugs/wires
-160 stat
-recapped "cheater" slicks P255/60/15's
Now I will say this, my buddy did all the work himself as far as installing the parts, minus the cat-back, but he spent no more than $1K. He also installed some gauges too, still, not going over $1K! This car ran the 12.6 @106 mph w/ NO problems at all, including driveability and gas mileage. I had all of his mods, but my car had 120K and I upgraded the turbo (TE60), 42 lb lucus "red stripe" injectors, Eastern Perf front mount, TH downpipe, ATR "pitbul exhaust". My best time was 12.6 @109 w/1.90 60 ft time and mind you the turbo I was runnin' needed a 3000 stall and the motor, although had 120K on it, needed new valve springs as they're pretty much gone by 60K due to the heat from the engine and general wear and tear. My combo was good for high 11's/low 12's but I never quite got there as I sold it before I could reach that level
Your car is quite rare as you know and BTW, does it have cloth seats
Also, whats the gearing in that car, I forgot
