Posts: 103 |
Sup, whenever i'm slowing down from high speedn my steering wheel begins to shake, i'm stumped. any ideas?
Black '00 CSVT #4 of 2150
K&N ru-3530, BAT MTF, Magnaflow exhaust, MSDS headers, and optimized y-pipe.
Posts: 16 |
Mine does the same thing. I am thinking it may be the rotors. I plan to check it out this weekend.
Posts: 3,637 |
your wheels may not be balanced. Could be a wheel bearing Could be a wheel stud (check to make sure they arnt coming off) etc etc etc
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 103 |
I the wheels balanced when i bought it, which was last week. but the tires are at the wear bar, almost toast the tire tech said.
Posts: 5,345 |
Originally posted by Chrisf695: .. but the tires are at the wear bar, almost toast the tire tech said.
This will cause vibration and shaking. If it continues after new tires and balance, then rotors might need to be "turned".
1996 V6 ATX 96K miles
Posts: 60 |
Originally posted by Chrisf695: I the wheels balanced when i bought it, which was last week. but the tires are at the wear bar, almost toast the tire tech said.
Why would you balance bad wheels for?
Posts: 1,788 |
Your brake rotors are warped.
You might get lucky and be able to have them turned, otherwise they will need to be replaced.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 4,693 |
Steve
This is the most likly answer. Almost for sure, you have brake rotor problems.
Jim Johnson
98 SVT
03 Escape Limited
