Posts: 103 |
Hey Guy,
I tried to search this topic but it couldn't find it, it came up with a can't display message.....well anyways will this fit a 98 Contour V6 ATX, i know this is for the cougar i just want to make sure.
thanks
attila
Got a 98 Contour SE ATX
Kill List:
Camaro V6 Integra GS Dodge Stealth S-10 Chevy Pick Up V8 96 Accord Cavalier z24 Honda Civic Chevy Pick Up Vortech V8 Toyota Celica GT
Posts: 2,066 |
thanks
attila I had it! And when I compared the MAF adapter to the KKM's it was way smaller. I kept the intake pipe and added the KKM later. I wouldn't get it. Just pick up a BAT intake pipe/MAF adapter and add a large K&N filter. You'll be much better off. Or you could go the easy route w/ the KKM but your top end will be better with the k&n. Hope that helps
Posts: 1,444 |
i was considering the injen intake too but recently researched and found this to be a common problem of small maf adapter.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 2,148 |
The intake pipe is nice....the rest of the kit sux. I still use the intake pipe, but the maf adapter and filter is collecting dust in my basement. The inside diameter or the maf adapter is about 10mm SMALLER than the maf. Just do like the others have and get the BAT pipe and possibly the KKM or similar intake. What I ended up doing was just adding a K&N drop in filter and drilling out a few 3/4" holes in my air box to open up the available air draw. Its just like having a heat shield I guess, but its not pretty.
Former owner of 1999 SVT Contour #555
Posts: 103 |
Kill List:
Posts: 157 |
I have a Injen on my car and it works great, but I try a pro about 2 years ago and it would not work. Do you think that its was the injen!
98csvt(red)white 19''Axis se7ens on toyo 225/35/19's injen intake,cust exhaust, High Rev's racing clutch,and flywheel .whatever its takes to run 12's (system)Eclipse 5442,Boston 6 1/2" pros, Eclipse 5x7 point scourse,PPIpc4400,PPIpc2600(chrome),power cap,2 12"JLW6 YOU WILL RESPECT THE FAMILY CAR
Posts: 157 |
I tryed a pro flow(is what i ment) sorry it did not work
