Posts: 124 |
anyone ever have problems with this harness? My speaker has quit as well as the door lock and window occasionally. How hard is it to repair/replace?
I am Canuckian
I am Canuckian
Posts: 4,168 |
Sounds alot to me like it is the conection right at the door. IIRC it is a twist mechanism that might just be a little loose.
Green 96 mystique gs 4cyl mtx
16.9 in the 1/4 mile @102500 miles
95SE in Midnight Red MTX
MSDS headers and y-pipe
SVT exhaust
SVT UIM
Optimized se TB.
Full pre 98 SVT body kit
15.741 @ 87.73mph :)
Posts: 1,399 |
Understand that I have never had the panels off on my SVT, but it sounds to me like you have a loose connection on a wiring harness in the door. I would pull the door panel, go in, and clean all the contacts, as well as using some dielectric grease to make sure things are well sealed up. At the bare minimum, I would check it out, as it is often something simple like that. Hope this is of some help.
98 Silver Frost SVT
97 BMW 540I Sport, six speed
"Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future"
"A coveted car should never stunt your life, but should make it more rich and interesting."
Posts: 124 |
Hi Phil, the twist mechanism do they have contacts or do the wires run threw them? Does this assembly twist off at the door and the door post? I cannot find my CD to check how this is made. Thx Also when the door is fully open the door lock sound (horrible) comes threw the speakers hahahah
Posts: 2,017 |
1996 2.5LT V6 Contour ATX My Tour+help/info pics
E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
Posts: 1,231 |
95 Merc Stique
Zetec 2.0 Auto
Posts: 2,807 |
Watch out for the black adhesive from hell, it stick to everything.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 124 |
I know how the door panel comes off and have had it off a long time ago. The issue I have is the sleeves( where I know the problem is, if I wiggle the sleeve the connection comes and goes) between the door and the door jam. Does this just twist off or do the wires run threw this into the door , I hope I do not have to remove the door to repair the wires. Any more insight into this? Thx guys Right now nothing works in the car doors
Posts: 2,017 |
Originally posted by SVTCANUK: Watch out for the black adhesive from hell, it stick to everything.
Oh Yah I forgot about that alien gooooooo....
Originally posted by Stephen Fischer: Does this just twist off or do the wires run threw this into the door
Well You could of found it at the link I posted above. All you had to do was look under doors... Linky Fig. 3: Rotate the connector to remove the wire harness from the door
Posts: 1,399 |
Originally posted by Stephen Fischer: Hi Phil, the twist mechanism do they have contacts or do the wires run threw them? Does this assembly twist off at the door and the door post? I cannot find my CD to check how this is made. Thx Also when the door is fully open the door lock sound (horrible) comes threw the speakers hahahah
OK, something has to be loose in there, because it sounds to me like something isn't properly grounded. If the door lock sound is coming through the speakers when the door is open, I would guess that the door is grounding against the body when closed.
Like I said, I've never had it apart myself, so I can't get too specific.....
98 Silver Frost SVT
