#1535583 03/27/06 12:11 PM
Hi,
I was changing the brake shoes on my 97 contour yesterday and I can't get the hold down springs back on. Is there a trick to this? I can't seem to compress the spring enough to twist the pin and have it hold.
I think the actual problem is that I only have two hands.
Thanks,
Steve
Semper ubi sub ubi 2004 Ford Ranger 1997 Ford Contour 1988 Honda VT800 Shadow 1980 MG MGB
If you reuse the old springs they often get bent out of shape. Pick up a brake hardware kit (comes with new springs and slider bushings) and use a pair of pliers to to put the new springs on. It only costs a few dollars and makes things much easier.
Good thinking - I'll swing by the store this afternoon. Thanks for the advice.
Steve
2
Usually what stops them is the shoes aren't fully seated. I have a tool that presses the whole retainer in and lets you turn it to line it up while holding the pin against the backing plate.
