Posts: 1,074 |
Brett
The man thinks its best for everyones safty if i dont drive for 6 months
'95 Moonlight Blue Contour (ITS ALIVE AGAIN!)
MODS:
Knauberized,Reverse Indiglo Gauges,LED's,AEM Intake,Rust holes for more power!
Posts: 1,889 |
The water is about 10degrees
It looks a little to fluid to be that cold.
99 Contour Sport SE MTX
KKM filter, B&M shifter
No res, BAT kit
Green car silver hood (because silver is faster)
Posts: 81 |
haha nice. I have done it before as well, well the first time i fell in, which is not all that bad. The second time i actually made it across with no problem.
Its fun to watch the people that are going across spray the crowd with water.
Which mountain is that?
Pretending to be someone your not is a waste of the person you are.
Posts: 3,143 |
"Bros before Hoes" <-- More men need this mentality.
Posts: 1,757 |
10 degree celsius is 50 degrees fahrenheit.
Looks like a blast! Where abouts did this take place?
Posts: 1,889 |
I'm not sure about MI(never have been ) but the rest of the US measures temperature the Fahrenheit way which would make 10 degree water 22 degrees below the temperature that water freezes at(thank you Mr. Science). That's when they stop calling it water and start calling it ice!
No res, BAT kit
Posts: 2,838 |
Well - I could f'n care less what exact temperature it is ... it looks WAY too cold to be flailing around in !!
It looks like a fun thing to watch , which is all I would be doing . Seems like you had a good time trying it out - you crazy foo !!
~~~~~~~ Phil
Black & Tan 2000 SVT Contour #2137 of 2150
35,000 miles & counting !
Posts: 1,074 |
Originally posted by Pete D: Where in NY is that?
It was at bristol mt (www.bristolmt.com) its about an hour south of Rochester.
Originally posted by RT and his SE: Originally posted by LittleFishie: Originally posted by RT and his SE: Quote:
What ever temp it was, it was cold enough that ice started to form so they had to delay the starting of the event and remove it. And it was pond water and had sat in the snow for 2 days. As soon as i hit the water i couldnt say anything, it was like a kick in the pants, my hand immediatly turned red and stung like no ones business.
But it was definately alot of fun.
Brett
MODS:
Posts: 4,220 |
Try freezing a pool of water when there's someone falling into it every couple minutes. It doesn't matter if it was -20, it doesn't stay still enough, long enough, to freeze.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 1,889 |
Mmmm I guess the laws of nature don't apply.
No res, BAT kit
