#115005 03/06/02 02:26 AM
Can you guys give me any suggestions. I tried to install an aftermarket intake pipe. The one that I purchased would not work on my contour. I have a 99 SE Sport V6. So I returned it back to stock. No the car idles rough, It shifts out of synk, and it knocks and pings like a pinto when I accelerate. How do I go about fixing this without spending countless dollars at the dealership. do you guys have any answers. I am calling to the contour gods
#115006 03/06/02 03:13 AM
Lee Offline
Sounds like you have a Air leak after the MAF. Check that all the clamps are on tight and the hoses are seated properly.
Lee Cox
In life begins responsability...
Project Car
#115007 03/06/02 11:10 PM
I assume after running it with the aftermarket pipe, you disconnected they battery to let the computer reset itself. And switching back to stock, like wise...
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
#115008 03/06/02 11:52 PM
I
I
Ding Ding Ding
#115009 03/07/02 03:31 PM
Sounds more like he ditched the MAF all together! eek
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#115010 03/07/02 05:08 PM
Administrator
Administrator
Either that or the IAT sensor is messed up. Wires bent/broken, or connector isn't on all the way.
Or, just a plain old vacuum leak after the MAF. Where's that damn pipercross thing? smile
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#115011 03/07/02 08:56 PM
Ding Ding Ding
I-Dom-In-8
Id suppose you didn't notice he was a new user? :p
#115012 03/08/02 03:43 AM
Yes i disconnected the battery before I installed the aftermarket pipe. I also disconnected the battery before and after returning it back to stock. In fact every time my check engine light comes on I disconnect the battery and reset the computer
#115013 03/08/02 07:11 AM
Might want to double check all your hose and electrical connections. It really sounds like there is a leak somewhere. I wouldn't bother disconnecting the battery anymore, the CEL will keep coming back as long as the fault condition is still there. When you get it fixed, the light will go out and stay out. CEL basically indicates that engine does not seem to be operating within normal bounds and is probably polluting more than it should. If a sensor is unhooked or a hose is leaking, you'll get the symptoms you describe.
Scott
