Posts: 129 |
I've got the UDPs that I purchased from Pete about a month ago, and they're going on my car next Wednesday. I even have the Gates belt #K060725. However, I've recently read some old threads that say the belt # is K060730. Which belt do I need for P/S and alt. UDPs? K060725 or K060730?
'98 CSVT Black
-AEM short-ram intake
-Optimized TB
-Optimized y-pipe
-Magnaflow cat-back
-B&M short-throw shifter
-UD pulleys
-Poly mount
"It's quicker than it was stock!"
Posts: 6,910 |
check the group buy threads, it is in all three of them
- 95 Mystique LS - Zetec/5spd
Posts: 129 |
Originally posted by BrApple: check the group buy threads, it is in all three of them
It states that you can use both. However, someone said the K060730 was easier was a little easier to install. Another person said the K060725 was a little short. I guess that answer speaks for itself, I'm just always careful when it comes to my baby.
'98 CSVT Black
-Optimized TB
-Optimized y-pipe
-Magnaflow cat-back
-UD pulleys
-Poly mount
Posts: 1,210 |
Both belts will work Go with the K060730 or even a 735
The 725 works as well but the tensioner is pretty much maxed out
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
Posts: 4,141 |
Originally posted by 96BlackSE: Both belts will work Go with the K060730 or even a 735
How about with just the P\S UDP? Fogured i'ld bumpthis thread instead of starting a new one.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 1,651 |
K060730 will still work!!
I reject your reality and substitute my own.
Posts: 4,141 |
Originally posted by Rickson: K060730 will still work!!
Thanks. Either you're not jellin, or you're really excited to tell me the answer.
Totaled 02/12/06
Posts: 1,651 |
Originally posted by pole120: Originally posted by Rickson: K060730 will still work!!
NO i am excited to put mine on.. he he
And of course i am sooo jellin.
Posts: 4,141 |
I ended up getting both pulleys installed over the course of the weekend, but for a day i had just done the P\s and the belt does fit FYI.....i actually thought the 730 was a bit short with both pulleys but the tensioner isn't maxed out so it's not bad.....
Totaled 02/12/06
