Posts: 81 |
Im in the middle of changing the clutch in my SVT. I have the fidanza flywheel and i need to know the torque specs that it requires for the pressure plate.
Thanks -Steve
Pretending to be someone your not is a waste of the person you are.
Posts: 21,197 |
Tell me you're not doing it w/o a manual?!!!!! Did you replace the TOB? What TOB did you use? What sealer did you use? Did you remove the rubber o-ring that comes on the Spec TOB?
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,361 |
'98 SVT Contour, in at least 639 pieces
4 Speed MTX...synchro and shift fork replacement in progress
Posts: 81 |
Yes im using a manuel and also knowledge. I have replaced the tob and what not. I know the manuel has the torque specs but its for the steel flywheel and since i have fidanza its aluminum so its a softer metal. sorry for any spelling errors im kinda running back and forth.
Posts: 10,015 |
Originally posted by beven6: Yes im using a manuel and also knowledge. I have replaced the tob and what not. I know the manuel has the torque specs but its for the steel flywheel and since i have fidanza its aluminum so its a softer metal. sorry for any spelling errors im kinda running back and forth.
PS make sure you are using hardnened washers with the bolts, on ANY ALuminum flywheel, otherwise you will not get the correct torque setting (80Nm) on the flywheel bolts and then could end up with a flywheel that comes loose!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 2,033 |
didnt u already have an aftermarket clutch on there??
Posts: 21,197 |
Originally posted by Stazi: PS make sure you are using hardnened washers with the bolts, on ANY ALuminum flywheel, otherwise you will not get the correct torque setting (80Nm) on the flywheel bolts and then could end up with a flywheel that comes loose!
Or 60 ft lbs. for those with a ft. lb. wrench.
-'96 SE MTX 3L
Posts: 1,336 |
Would you recommend locktite as well? I used it on my SVT Flywheel and definitely planned on washers + locktite on the Fidanza.
Posts: 81 |
Originally posted by fastcougar: Would you recommend locktite as well? I used it on my SVT Flywheel and definitely planned on washers + locktite on the Fidanza.
Yea, i used locktite as well for the bolts. All that is left for me to do is put it all back together now
Posts: 6,791 |
Originally posted by todras: Originally posted by Stazi: PS make sure you are using hardnened washers with the bolts, on ANY ALuminum flywheel, otherwise you will not get the correct torque setting (80Nm) on the flywheel bolts and then could end up with a flywheel that comes loose!
80 Nm = 59.00488 Ft/lb
60 Ft/lb = 81.3492 Nm
Exact
... Yeah I'm bored
