Page 2 of 2 1 2
bhofman Offline OP
The car doesn't run noticably slow, although it's almost 10 years old, so it doesn't run like new.
A couple years ago I had a low power problem, especially in warmer weather, but I cleaned out the intake and it seems fine now.
I am going to try to make my own MIL Eliminators. I found directions, including a list of parts to buy at Radio Shack. Sounds easy, and I can save some $ and get them installed sooner.
Thanks for the input.
Brad Hofman 96 SE MTX
9
Where did you get the directions from? That would be awesome since I've had a PO171/174 for a year now, and still have not found the problem short of replacing everything. Hopefully that would work! Good luck on yours!
Sean
'99 Silver SVT Contour (2000 miles since June, now needs new front brakes and bearings) '98 CBR900RR Again (Put away for the winter)
Originally posted by 99CSVT:
Where did you get the directions from? That would be awesome since I've had a PO171/174 for a year now, ...
Your code combination is due to a vacuum leak.
MIL eliminators are for the P0420/P0430 codes.
GOOGLE "make your own MIL eliminators"
Steve
9
Actually, that's what I meant. I got the codes mixed up, but thanks!
Sean
Page 2 of 2 1 2
