#1531406 03/21/06 05:14 AM
W
W
Hi. Before I test the wires going to the fuel pump, wherever they are, I want to check the fuses. The problem is I bought my 1997 Contour used. It ran enough to drive it home, but has sat for several months. Apparently I need the owner's manual, which is gone, or a Chilton's, the Haynes I have does show the fuses IDs. So since everything is closed, does anyone know where a diagram of the fuse panel exists on the web or which interior fuse is for the fuel pump. I checked all of the fuses in the engine compartment and they were good. My Contour has a 4 cylinder engine. Any help would be appreciated.
Thanks.
#1531407 03/21/06 05:32 AM
fuel pump fuse is under the hood # 12 or #13 IIRC
96' ATX Zetec- stock 96' ATX Zetec- Modded Kenwood KDC-319 5.75"-2 MTX 12's Roady XT Custom door panels Mystique Cluster/oil pressure Getting repainted(in primer) Pre98 Lip SE skirts Mystique front lip dingless badgeless
#1531408 03/21/06 02:11 PM
Download the Owners' Manual free www.fleet.ford.com
#1531409 03/21/06 05:42 PM
W
W
Thanks! That is exactly what I needed.
