#1531260 03/21/06 01:10 AM
9
99tour Offline OP
9
I want to replace my upper o2 sensors in my 99 contour 2.5L. After doing a search I found that most people use bosch part #13115 for the uppers and part #13133 for the lowers. But the parts store had bosch part #13741 listed for the uppers. I also searched at www.boschusa.com and found that they also have part #13741 listed for the upper o2.
Has anyone else encountered this? I wonder if they replaced the 13115's with an updated part. Would like to here suggestions and opinions please.
THANKS.
I can't help you with the Bosch numbers. I usually avoid Bosch because of their arrogance when I worked in a Volvo dealership. Bosch had an attitude of "we never have built a bad part, you must be mistaken".
I bought my oxygen sensors here, from the CEG FAQ section:
http://www.oxygensensors.com/
2
The Motorcraft sensors are easier to install on the back bank because they are shorter.
9
99tour Offline OP
9
I'd like to use the Ford o2's but they are more expensive, so I have to look for an alternative.
Anyone else have any comments on this post?
I have 4 Bosch O2 sensors; installed by an independent mechanic 2 years ago so I can't help you with the part numbers.
2
The Motorcrafts were the same price as the Bosch around here.
