#1530981 03/20/06 06:52 PM
ok i seen the sticky on the fuel filter how to but my problem is this. where it tells you to remove the (15) fuse i removed 2 fuses that were under the hood with the number 15 on them and i turned the car on and it still was running but the idle was crappy. now i need to know which fuses need to be removed so i can change my filter oh i have a 00 svt thanks
#1530982 03/20/06 07:00 PM
Download the Owners' Manual from www.fleet.ford.com. It has the fuse numbers and location.
For the 1996, the fuse is No. 14. It is one of three 15 amp fuses (four if you have fog lights) in the Power Distribution Box next to the battery.
#1530983 03/20/06 07:35 PM
LMAO
Ryan Trollin!
#1530984 03/20/06 08:03 PM
Yeah, I know. Let it slide
98.5 SVT FOR SALE $5000
#1530985 03/20/06 08:06 PM
E
E
I did my fuel filter this past weekend. Check: Sticky at top of forum
Here is the proper 15amp fuse to pull. Then turn the car over a few times, it will eventually not start. You have turned off the fuel pump by pulling the fuse. All you are trying to do is depressurize the fuel lines.
There will be gas spilled. Even if you get the lines depressurized, there is still some gas in the filter itself... It wasn't too bad for me though. Just be careful with your eyes and not to be laying too close beneath the filter... Gas in the eyes SUCKS! (Happened to me the first time swapped that filter out).
The instructions (link above) are really good. Just follow them. It's a very easy thing to do.
MUST SELL - ECM computer new for a 98 V6 mtx + pats Now trolling in a Red Nissan 4 x 4
#1530986 03/20/06 09:27 PM
and don't use hand sanitizer to clean up if you do get some on your hands. Basically makes its own glue(don't ask).
95 LX-with a mind of its own 24v DOHC SVT exhaust and K&N=all thats worth modding Go Fighting Sioux!!!
#1530987 03/21/06 12:58 AM
I have never bothered to depressureize the system before changing the fuel filter. I don't know any tech's that do.
Another (easier) way to depressureize the system is to depress the stem on the schreider valve on the fuel rail.
#1530988 03/21/06 01:58 AM
after placing a catch rag over the valve itself, to be safe, that is.... press the valve in through the rag.
#1530989 03/21/06 02:43 PM
ok thanks so much for the response guys but i ended up getting it done yesterday. it was very easy. i seen the picture but there were 2 other 15(fuses) and my fuse box dont look like the picture which threw me off big time but like i said i got it done thanks again.
