#114687 02/27/02 04:31 AM
Y
Y
I am thinking about trying a TB spacer. How hard is it to pull out the old studs and put in new ones?
Yankeyspeed: American power and ingenuity
95 SE -Stock enough
Yeah my car has a baby seat, its still fast.
#114688 02/27/02 04:37 AM
TB not on studs. Four 8mm bolts attach TB to upper intake. 1/4" socket wrench is fine for loosening these. Please post a pic of your new throttle linkage setup when you get the spacer in and working.
Scott
#114689 02/27/02 04:41 AM
Y
Y
COOL. I am going to try to make it out of wood (Maple) I will keep you posted.
95 SE -Stock enough
#114690 02/27/02 09:46 PM
Yor can use the stock bracket with only a few small modification pieces (keeping it intact!)
Notching the spacer and an extension piece & block.
2000 SVT #674 - Check it out!
#114691 02/28/02 02:31 PM
Been there done that I have the T-Shirt. The spacer made no improvements. The manifold runners are already pretty long so I don't think it will help much unless you are going to put a septum in to seperate the air flow. I welded mine out of steel for concept. Also it is a pain in the arse to get the throttle cables to work correctly. I had to have someone pull the cable while the dyno was running.
If it's true that we are here to help others, then what exactly are the others here for?
#114692 03/03/02 02:36 AM
Y
Y
Hey Can I see the shirt? How long was your spacer? And Yeah I am using the stock cable mounts, just extending the mounts.
95 SE -Stock enough
#114693 03/03/02 05:02 AM
Don't have a camera sorry. wink It was about 1.5".
