If all of your readings are even, it isn't likely that you have an obvious head gasket leak.
A better way to tell if you have a coolant leak into the cylinders is to remove the spark plugs and pressurize the cooling system after sitting overnight and then have someone crank the engine while you watch for coolant out of the plug holes.
Coolant leaks into the cylinders are sometimes hard to pin down. I'm betting that it is something else though.
