So I purchased the cable and downloaded the software from Alex Pepper's OBD-2 website. Wow, it has a lot of information. Here is what I am trying to fix:
Very poor gas milage
DTC's of P0171 and P0174.
I have checked for Vacuum hose leaks, replaced fuel filter, I am getting 40 PSI at the fuel rail and sprayed MAF with intake cleaner twice. This past summer I had the engine torn apart to repair the #2 spark plug thread that striped out. I replaced the UIM and LIM gaskets when I put it back together torqued every thing to spec. However, a month after I did this, the UIM bolts had worked loose and were less than finger tight, so I torqued then back down to ~90 IN/LBS and the codes returned. I am going to do the UIM/LIM cleaning again this weekend and replace the UIM/LIM gaskets again as well.
What should I be looking for in the testing and data from the OBD software?
I have a KKM filter installed and an optomized Y-pipe.
