Posts: 3,637 |
Originally posted by Matty K: Beating a dead horse:
To be totally, 1000% clear: I'm doing full headers. It's a MSDS set, with a two bolt flange. My car also has a two bolt flange. So, I should be good to go, right? The nature of the two-bolt flange allows give, so there's no worry about cracking or need for a flex?
Also, does anyone have a pic of headers installed, looking down from the top of the engine? I just want to see how visible they are.
Correct.
The headers are barley visible.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 6,910 |
you will need a new gasket for the y-pipe to cat flange otherwise two bolt y-pipe to 2 bolt cat is good to go
you can't see the front header unless you are looking for it ...
- 95 Mystique LS - Zetec/5spd
Posts: 3,637 |
Originally posted by BrApple: Originally posted by Matty K: Beating a dead horse:
What?
When i did my headers there wasent a gasket bewteen the cat and the Y-pipe. IIRC the Donut flange acts as a gaskets, much in the way the y-pipe connects to the manifolds.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 6,910 |
Originally posted by Tourige: Originally posted by BrApple: Originally posted by Matty K: Beating a dead horse:
What?
there is on the stock 2-bolt y-pipe, maybe the headers don't have one but that doesn't make much sense to me ...
Posts: 3,637 |
Mine did not have a gasket on it..
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 3,867 |
Originally posted by Tourige: Mine did not have a gasket on it..
Another vote for the donut. I put the MSDS Y on my car and required exactly 0 gaskets.
However, the Y to Cat connection with the donut has some special bolts/pins--crazy expensive and I couldn't get the pins out, and I ended up breaking one of the bolts because I didn't know what I was doing. I still need to go back under there one of these days and fix the redneck engineering I did to get it all running.
Function before fashion.
'96 Contour SE
Posts: 3,637 |
Originally posted by RogerB: Originally posted by Tourige: Mine did not have a gasket on it..
yea, mine came out easy enough, they just needed some tugging, Definatly a weird setup.
I hate the person who designed our cars.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 7 |
Yeah, I broke one of those bolts too. I just went to the local hardware store and bought some 2 1/2 inch bolts, nuts, and washers. Put a washer on the bolt, put it on, put on the spring, another washer, then the nut, and good as new! I works just like the stock set up, and cost all of $2.00.  I bought 7/16 bolts, so they are nice and thick to deal with the stress put on them by the flexing exhaust.
1999 Mercury Cougar V6 MTX
Injen SRI with GMK CAI Extension
MSDS Y-Pipe
Trubendz Dual-Outlet Borla
B&M Shifter
