Posts: 27 |
what type of magneflow muffler should i get to replace my stock mufflers on my svt and how would it sound with the resonator cut of off the car to?thanks for the help Matt
2000 svt countour (stock for now) 2001 gsxr-600 with mods
Posts: 3,237 |
If you want direct replace ment Magnaflows then the ppart number is 11124 and I can get them for $70 each.
Posts: 27 |
how what it sound if i did the direct replacement with the magnaflows and could i use diffrent types of magnaflow to? Matt
Posts: 3,237 |
It would sound pretty good. An the type of Magnaflows you could run really depends on how much money you have to spend, as other styles of muffler will require a little bit of custom piping to make them work.
