#1525846 03/14/06 01:05 AM
I have the wonderful DTC 332 code. Checked egr with suction test and engine did die as supposed to.
Vacuum harness is in new condition.
EGR vaccum solenoid tested fine.
Replaced Vaccuum solenoid (down by DPFE) and replaced DPFE. Hoses to DPFE are generic hoses FORD sold to me....not like the original ones. Precats were replaced about 2 years ago.
Pulled upper intake and removed throttle body, still very clean from last time removed.
Any ideas appreciated....
Bob
Well I found the problem. I went out and again purchased two new DPFE hoses and put them on. Problem is now gone.........
Can't figure out what was wrong with the first set....
Bob
LOL. Eventually, you find the solution to your problem. Thanks for posting your solution, Bob.
