#1525355 03/13/06 01:30 PM
H
H
I had the sunroof gear problem that so many people have had. I ordered a gear from odometer gears.com and installed it. however, now my radio, clock, and lights do not work, yet i didnt touch anything up there? Is there a link between those items, could i have accidently messed something up up there, does anyone have any idea what happened? If anyone can pull there lights down and take a picture of how they are wired, so i can compare, that would be nice too!! Thanks
1998 CSVT KKM Intake Bosal CatBack SHO Shop YPipe Magnacore Superchip I am a follower of the great "I AM"
#1525356 03/13/06 06:47 PM
OPen your owner's manual to the section on fuses.
Look up the devices that don't work and see if they have fuses in common. Check those fuses carefully.
Owner's manuals can be downloaded from www.fleet.ford.com if you don't have one.
Steve
#1525357 03/13/06 06:50 PM
This should help.
Originally posted by ZeroHour:
Well I found it. Anyone else in future reference:
Under the dash, driver's side is your fuse box (duh, but if you're new its a start)
find some uncomfortable way to lay there.
Facing upwards, to your right is a white-ish plastic box with wires. There is a small level, it opens the box.
Fuse #32 is interior lights, head unit(radio) and clock! its a 7.5 amber colored fuse. You should have on in your fuse box under the hood, along with a fuse puller!
Easy to find search action sentences:
No interior lights
interior light fuse
Head unit not working
Head Unit Fuse
Clock not working
Clock Fuse
Hopefully that helps someone else in the future cause I couldn't find much searching!
#1525358 03/14/06 12:53 AM
H
H
checked fuses, nothing wron gwith them!
#1525359 03/16/06 03:01 AM
H
H
nobody can figure out anything else with this? could it be a ground wire or power wire, are they all interconnected or have seperate, any help would be appreciated!
#1525360 03/16/06 04:05 AM
H
H
OK, upon furthur inspection, i opened the overhead light compartment, and found that some of the wires appear to be missing, can anyone pop that down and take a picture of it for me, so i can see what wires are missiing and where they go, so i can try to fix this?!
