Posts: 29 |
first off....I have a 99 'tour v6 se 5 speed w/tach. Can i swap in an svt gauge cluster?
second....how can i find my paint code...ford has like 10,000 greens
thanks in advance
Hi how ya doin? I live in Holly, MI and im new to the contour. Ive got a 1999 contour se V6 5 Speed
Posts: 1,578 |
yes you can
look at the manufacture's sticker inside on the B pillar, it says exterior code then two or three characters, I can't remember
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
98 'Tour SE 24V 5-spd
149 HP @5900
148 LB FT @4300
Posts: 29 |
alright cool, thanks alot
Posts: 3,637 |
Maybe you want to tell him that the SVT speeda goes up to 160 whereas the SE dosent, (i think its 130 or 140) so he will need to re-calibrate his speedo..
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 604 |
se goes up to 130. and how do u realibrate the speedo???
G/f's black 99se sport 5 speed
2 1/2 test pipe-custom cat back 3 single tip
cai with kn3530
safc optimized tb
8mm plug wires
spec stage 1 clutch
svt front bumper
Posts: 29 |
yeah i seen the svt goes to 160. but where can i get it calibrated? and is it a direct plug and play other than the calibration? thanks alot.
Posts: 3,637 |
the guages are just plug and play and the install should be fairly basic, i have no idea how to calibrate the speedo tho, sorry
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 604 |
ok could someone who has done thing chime in so we both can learn something new today
cai with kn3530
safc optimized tb
8mm plug wires
spec stage 1 clutch
svt front bumper
Posts: 1,882 |
Originally posted by pimpdcontour: ok could someone who has done thing chime in so we both can learn something new today
From my understanding, If you've god OBD2 you'll need to jack the car up on stands, plug in a OBD2 diagnostic tool, start the tires running, and calibrate. That's the extent of what I've been told:
Originally posted by buckeyesvt: On the speedo, pushing it back will do nothing. You would need to calibrate it while it is displaying speed (preferrably while sitting still). It is very dangerous to do this on any road, no matter if it is a side street! You can use jack stands and wheel chocks and get the front wheels up and get the car up to 25mph or so. Then attach the needle holding the speed steady. You should have a scan tool with data stream to do it right. Most OBD2 code readers allow a datastream type capability to read the VSS (Vehicle Speed Sensor) signal and report the wheel speed. Then you can remove the needle without worry about errors. You cannot just turn the key on and set the pointer on 0, it doesn't work like that.
