A couple of questions before these guys go on...
- Did anyone else drill hoes in the bottom of the connectors to allow water to drain? Good or bad idea?
- I'm planning on getting these powdercoated. Should I get the whole connector coated and let the installer grind off the coating where he needs to weld (then spray paint)? Or should I leave part of the connector uncoated for welding purposes...
Thanks guys
