Posts: 68 |
Cross post on NECOif you cant see the pics, when i compress the SPEC TOB, the inner ring is flush with the thing that contacts the PP. When i compress the Ford one, the PP contact ring compresses further down past the inner ring. wtf? i talked to bill j yesterday and i got a brand new V6 TOB.... help  thanks
Cougar is no more, parts for sale.
Built escape 3.0 w/ 8.5:1 pistons, PnP heads, ovalport/mazda6 cams, SVT manifolds, the works
entire car for sale PM me if you want a part!!!
Posts: 21,197 |
Might not want to spend all your time over there.  The TOB where the piston moves back far below the tube face is a ZETEC TOB...didn't we cover this before? It will have a raised ridge on the bearing face and is far shorter than the V6 part.
Ahem.
Ahem 2
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 68 |
guess what guy? i read both those threads twice.
both TOB's in my possesion are exactly the same. they measure the same height and have the same part number stamped on them.
now care to explain why one compresses farther than the other?
[image]http://www.newcougar.org/forums/attachment.php?attachmentid=23391&stc=1&d=1141960616[/image]
[image]http://www.newcougar.org/forums/attachment.php?attachmentid=23392&stc=1&d=1141960616[/image]
Posts: 68 |
can anyone answer my question?
Posts: 4,693 |
Links don't allow to view photo's without a password. It might be easier to see what you mean if we could see the photo's.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 980 |
I'm in a good mood.FORD TOB SPEC TOB
2000 Mystique LS
Duratec 2.5L MTX
Posts: 21,653 |
My guess is that if the SPEC is made by another company trying to match Ford's design, then it could be different when compressed.
I'd use the Ford one (which the v6 ford tob I have compresses down the same as your's, with the outer part going further down than the inner ring).
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 68 |
k, hopefully this works, i just installed the brand new OEM ford unit.....
Posts: 5,810 |
Really guys, that compression thing shouldn't be a big deal. Although I agree they should be the same, that wouldn't make them not work. You have to take into account the whole travel distance of the piston/bearing assembly.
See My Mods
Posts: 21,197 |
{TH}.....'Really guys, that compression thing shouldn't be
...not quite right.The slave/TOB moves further down
and moves the piston BACK into the cylinder as the
clutch wears.A diaphragm clutch spring fingers move
OUT towards the TOB as the clutch disc wears and gets
thinner.If the TOB piston cannot move back the clutch
will become disengaged over time and slip.This type of
design is self adjusting....the amount of travel
remains the same re TOB piston stroke but it is the
position of the piston in the TOB that changes as the
clutch wears.....get it?
-'96 SE MTX 3L
