#1521646 03/09/06 02:27 PM
Does anybody know what the fuel pressure should be? (99 2.5l Mystique). Also, has anybody had their fuel regulator go bad?
#1521647 03/09/06 07:01 PM
2
Around 30-32 at idle and up to 40 off idle. Easy way to check is to pull the vacuum line out of the intake and plug the hole with your finger. The pressure should jump up 10psi when you pull the vacuum line.
#1521648 03/09/06 11:39 PM
This only works on return fuel systems with a vacuum FPR.
#1521649 03/10/06 12:45 PM
Since he has a 99, he should have the returnless system.
Steve
#1521650 03/10/06 03:25 PM
Hey guys, I have a returnless style fuel pump. Well I hooked up the fuel pressure guage to the schrader valve and turned the key to the on position and came up with 70psi? Is that correct, seems high to me? The car still won't start?
#1521651 03/10/06 10:56 PM
That is more than enough. Inadequate fuel pressure obviously isn't the reason the engine won't start.
Got spark?
Tried cracking the throttle 1/4 way while cranking?
Steve
