#114317 02/19/02 09:58 PM
Hey i got a shift light and i am wondering where the best place to tap into the tach signal wire would be.. anyone got any ideas?
99 SVT with resonatorless exhaust and open element intake
Sound System:
Clarion touch Screen Source Unit
Focal Components,Audiocontrol eq,
eclipse Subs and Amps
#114318 02/19/02 10:08 PM
Kai Offline
Sure do! Take a look at my tachometer install here and you should be able to find it. Hope that helps!
Kendall
'97 GL Zetec ATX
" Nippy "
#114319 02/20/02 09:57 PM
Kai, i put a tach on my car, but i hooked the sensor wire to the stupid "distributor" cus i kept looking in the Haynes manual for the damn wire from the ECU but they never had it right.. could that be why my car was reading 500-600 rpm's lower than actual as opposed to putting it on the fuse wire?
*fixed* 1998.5 Contour SE Zetec
No Cat, SVT Dual Exhaust, 2 N1 Mufflers, IAT , Diablo Chip, Iceman Intake, Polished TB, "new tranny"
Various other crap, no more mods for a while, just moved.
17.391 @ 81.03 mph
1995 Honda Civic CX Hatchback
15.34 @ 91.67mph
stuff.
#114320 02/20/02 11:36 PM
Its in Haynes,thats where I got it.
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
#114321 02/21/02 02:22 AM
Kai Offline
Yeah, probably so. Since the Contour is distributorless, tachs aren't really read the revs unless there is a wire coming from the computer. Luckily there is. You probably want to change it. smile
Kendall
'97 GL Zetec ATX
" Nippy "
#114322 02/21/02 04:30 AM
You might also explorethis arrangement. The Venom system uses it to monitor RPMs - tap into the brown wire here:
I don't have my instructions with me(and I'm colorblind), can any one else using Venom confirm wire color for Mr. Scott........
Mark
#114323 02/21/02 01:23 PM
Pin 48 out of the ECU harness (White wire/Black stripe) is the wire you can tap for your Tach/Shift-light and ofcourse, A'PEXi S-AFC.
This is the wire I tap for reading the rpm's on the A'PEXi. It is dead-on accurate.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#114324 03/08/02 03:59 AM
To tap into the tach wire, open your hood. Locate the center of the firewall. There should be a wiring harness connected to a rectangular piece of plastic(a.k.a. ignition control module). Attach the wire from your shift lite/ tach to the white wire with a black tracer(white w/ black stripe). Thats IT!!!
