Posts: 56 |
I have been reading and did a search without being able to find my answer. I am about to buy a set of of springs eibachs-front, h&r's-rear, I was just curious if a 225/50R15 will fit without rubbing, or would i be better off to go with a 215/55R15 tire, I am going to be running stock rims. Thanks in advance Jamie
1998 mystique 4 banger atx (wrecked)
1998 mystique V6 MTX --magnaflow muffler-no res, open cone intake(Ractive filter)
Posts: 4,693 |
The 215/55R16 won't fit. It is too tall. The 99 and newer SVT tire size is 215/50R16.
Someone else will have to answer about the 225/50R16 with lowering springs, but they work fine on my stock hieght 98 SVT E0.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 56 |
Originally posted by Big Jim: The 215/55R16 won't fit. It is too tall. The 99 and newer SVT tire size is 215/50R16.
hey jim I only have 15 inch wheels, so that will give me an extra inch of clearance so I think I should be fine I hope, but would really like one of the wheel/tire experts to give me there advise.
Jamie
Posts: 4,693 |
Maybe I need to learn how to read. Anyway, this may help: http://www.miata.net/garage/tirecalc.htmlI suspect that you may still need to hear from others that have already done this.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 4,270 |
i ran a 225/50/zr16 with no rub with koni and B+G sports
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 56 |
Originally posted by 5V7 Dr1v3r627: i ran a 225/50/zr16 with no rub with koni and B+G sports
thanks, if you where able to run those i should be fine with 225/50r15, since my overall diameter will be shorter with the 15 inch wheel. thanks again jamie
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Ran a 225/50zr16 with H&R's and Konis and the driver Rear rubbed
Fender needed to be rolled!
