Posts: 28 |
Everyone post your car's miles w/ what repairs and such. Could also post miles of friend's/other people's cars you know of with high mileages.
Posts: 495 |
2000 SE Sport 160K miles (original owner)
Non-routine repairs(i.e. stuff other than brakes, fluids, belts, tires, batteries, plugs,etc):
Heater fan resistor
IAC valve
Throttle Positioner Sensor
Alternator
AC condensor(thanks to wayward raccoon)
Fuel pump
Winshield(thanks to wayward buzzard)
That's it! (knock on wood)
Martin
My Profile
2000 Contour SE V6 ATX 170K miles
Hecho en Mexico
Steel blue w/greystone interior
1997 Volvo 850 Wagon 146K
Posts: 160 |
1996 GL ATX, 97,7xx
valve cover gasket (being done at the shop right now).
Thats been it. Maybe wiring harness. Am the 4th owner though.
96 Contour GL 2.0, ATX "Herman" 101K
"A Clean zetec is happy zetec"
Posts: 5,143 |
Originally posted by zetec herman: 1996 GL ATX, 97,7xx valve cover gasket (being done at the shop right now). Thats been it. Maybe wiring harness. Am the 4th owner though.
you had a shop replace you're valve cover gasket? Im sorry, but um... Thats like a 20 minute job, its almost as easy as replacing your spark plugs
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 1,505 |
131,739 replaced fuel pump, replaced everything inside the gas tank and windsheild.
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 1,317 |
1999 SVT 37k miles. Regular maintenence since i've had it. dont know maintenence record before i owned it. R-Title
~Ryan
1999 T-Red SVT Contour
41k Miles #1701 / 2760
B&M, Custom Y-Pipe, Alpine HU, Pioneer 6x8's & 6x9's
Posts: 777 |
A little over 45,000 miles. regular maintenece, no issues. stored winters. original owner.
"we aren't punished for our sins, but by them"
2000 se sport tropic green/gray leather.
V6,svt body kit and E1 wheels/Avon tech m500 rubber, many mods.
2003 Eddie Bauer Explorer V8
2001 Suzuki Bandit 1200S
1996 Mercury Sable
Posts: 1,150 |
1995 SE 200,000 miles --> way too many things replaced. Put it this way: nothing is original except the motor and trans which has a new head and a 3 yr old clutch. So basically it is and entirly new car...
throttle cables to paint to interior to spare tire even! too many to list - want more info just ask!
Posts: 536 |
213,000
replaced valve cover gasket regular maintance
still runs strong
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 217 |
2000 svt 83xxx miles. Replaced water pump. 2nd owner.
2000 svt contour
1996 oldsmobile eighty-eight
