Page 1 of 3 1 2 3
#1517574 03/03/06 08:48 PM
I'm at ~160,000 miles and my baby is starting to leave little dark spots on the driveway. Seems to be leaking from several spots on the engine. Short of replacing gaskets my mechanic suggests switching to 10W30 for less leakage. Any big cons to doing this?
98 Contour V6 MTX, T-Red, 150k mi. Pic SVT Dual Exhaust, KKM Intake, Donnely Mirror, Dension DMP3 Player w/80GB of MP3s, Wheelskin 95 F-150 91 Mustang GT 06 Honda Shadow Aero
#1517575 03/03/06 09:03 PM
Might be too thick for the oil to fit in the bearing clearance... but not as bad as if you were to use say, 50 weight.
Your engine might be worn enough that it wouldn't matter anyway.
But I don't think 10w30 is going to help your leaks much.
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
#1517576 03/03/06 10:31 PM
Don't expect any appreciable change. Since there is no oil produced today that is too thin (or thin enough) for a cold start, and most engine wear is during warm up, why generate the additional engine wear in an attempt to slow down a little leak?
#1517577 03/03/06 10:42 PM
Jim is (as usual) correct. You may be able to slow leaks (and even improve compression, etc.) on an older engine by using a thicker oil, but don't! It may seem like an improvement, but it's just hiding the problem, and possibly making it worse. If you want the engine to last, try to find the problem and fix it.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
#1517578 03/04/06 02:12 PM
Try adding a bottle of Valvoline Max Life additive to your oil.
Over a couple of thousand miles, the additives can cause gaskets and seals to expand a bit and add so life to them.
Steve
#1517579 03/04/06 06:44 PM
E
E
THat is the worst oil EVER!!! My freind and I both used it once and our cars both ended up buring like 4 times as much oil as ussual. (he used it in is 98 mustang and my 92 talon). I couln't believe it.
95 SE MTX svt exhaust intake deer killer
#1517580 03/05/06 06:00 AM
i run 10w 30 in my zetec no probs. i use castrol gtx for high mileage.
1999 Ford Contour SE Zetec with 137k miles. AIM Name: ContourAlf Yahoo IM: Contour_Freak
#1517581 03/05/06 09:30 AM
E
E
doesn't the manuel say 5 weight oil? Why would you run a thicker oil then that?
#1517582 03/05/06 01:47 PM
I agree. Why would you use a different oil then ford suggests? My shop teacher decided to try a thicker oil in his Mercades for winter driving, when we changed his oil well pulled the filter cartridge out and it was disquesting, the fins on it where all bent up and stuff. I would sincerely suggest you put 5w-30 in like the book says.
#1517583 03/07/06 11:59 PM
THat is the worst oil EVER!!! My freind and I both used it once and our cars both ended up buring like 4 times as much oil as usual. (he used it in is 98 mustang and my 92 talon). I couln't believe it.
I have run it in my late dad's wagon, which was leaking all over. Stopped the leaks completely, and I haven't had to add oil since.
I have a friend who had a similar problem, and Castol's version stopped his leaks.
98 Silver Frost SVT 97 BMW 540I Sport, six speed "Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future" "A coveted car should never stunt your life, but should make it more rich and interesting."
Page 1 of 3 1 2 3
