Posts: 26 |
I'm about to replace the starter motor, and did a search in the earlier posts on how to do it. I removed the battery, battery tray, airbox, filter, the mass airflow sensor (?) section of the intake. But I can still barely even see the starter itself let alone try to take it out. Has anyone done it lately who can give me a quick rundown what to do next? Or is really the best approach to work kinda blind at this point and remove the bolts, etc like that? Also a list of recommended tools would be greatly appreciated.
'99 SVT (black)
Posts: 21,197 |
Remove the 2 bolts the connect the black cable to the starter. A 13mm and a 10 I think. The starter is bolted to the trans with 2 13mm bolts on the later models. A gear wrench is your friend here.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 47 |
First disconnect the battery and remove. Then remove the air cleaner assembly up the MAF. Then I partially drain the radiator and then remove the hoses that run over the starter. I tie back the large hose that goes to the radiator. the other two I loop back to the firewall. At that point you can reach the front bolt with closed end wrench. A 3/8" drive socket should be sufficent to remove the back bolt. I slip the starter out under the fuel lines. I know the book says to remove the fuel lines, I dont. That way the fuel system does not need recharged. I have gotten to the point that it is 40 minutes start to finish. The first time I was into the starter it took 10 mins. just to find the #$%$$# starter.
Good Luck Dan
96 SE 2.5 V-6
89 Silverado 4 x 4 with snow plow no rust
Posts: 26 |
Thanks for the info guys, I'll hopefully get to it this weekend!
'99 SVT (black)
Posts: 24 |
Dan, When you say "partially drain" the coolant, can you be more specific? There are a couple of hoses that run over the starter - are saying we should disconnect those and pour the radiator fluid into a container from that hose, or is there another way to do it without sending coolant all over the engine block? I too would like to avoid messing with the fuel system.
Horsepower is more expensive than crack.
Posts: 7,100 |
drain it from the petcock underneath... OR.. just undo the hose and lift it up, tie it back and only lose about 2 oz, if you are quick!
'99 CSVT - Silver #222/276
Posts: 785 |
im actually doing the same thing, and i didnt remove the fuel line, just unplug the big rad hose around there. the back 13mm was quit hard to get at first.. but i succeded to remove it, im currently waiting for the new one so i hope to replace it there will be as easy.
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
