#113994 02/13/02 06:38 PM
Has anybody looked into this for vehicles that will be getting some turbo action? I remember reading in SCC about how they got parts coated on a 300Z engine that increased its longevity.
http://www.swaintech.com/
#113995 02/13/02 07:56 PM
I went with Jet Hot Coatings Jet Hot Coatings I coated the Sho Shop Y-pipe, Catalytic Con., Cold air Intake, and will be shipping out the Upper Intake Manifold this month. There work is very impressive. I have some pics if youd like to see. (Just let me know)
I noticed lower engine temps, and for instance the cold air intake can be touched after an hour of hard driving. The sterling finish looks like Chrome.
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
#113996 02/13/02 09:24 PM
Yeah, I've heard that Jet Hot is does really good work, but I'm talking about the internals.
#113997 02/14/02 01:39 AM
Swain has good reviews.. I don't know of any users personally, but I did have a buddy who used Techline Thermal coating on his Turbo Volvo(a 2.3 inline 4) and the temp differences were amazing. He coated the combustion chambers, valve faces, piston tops, and then used a different caoting on the inside of his Exuast manifold and turbine housing , and then their high temp 2000+ black on the exterior, and WOW... Before when the engine would heat up to opeating temps, you would have to wait about 4 hours for it to cool back to ambient(turbo housing, etc...) but with the cating it was back to ambient in under 2 hours...To me, if you are tweaking an engine, this alone is reason enough to coat things,but also when you think about things thermally, if the engine parts are not absorbing as much heat from combustion, then the excess temps that would normally be abosorbed bt the head, tubo, exhasut manifold, etc... are being evacuated with the now hotter exhaust gasses, thus an increase in exhasut velocity(hotter gasses fow faster than cooloer ones), allowing a larger diameter pipe to be used with out as much flow decreases. Also , longer life on the water pump and the turbo's center core.. alot of good reason's to use engine coatings...
Good luck laugh
Tony Blatnica
99 Contour SE-Sport 2.5ATX
SVT Exhaust - Removed resonator
TH-Fix
#113998 02/14/02 02:08 PM
That's the exact way I was looking at it. I plan to have this done if I ever throw a turbo kit on.
#113999 02/14/02 05:59 PM
MM&FF has part of an article about Swain Coating.March 2002 issue..the article covers a 5.0L engine intake manifold modification...last process was Swain coating and results.Looks impressive.
99 SE Sport..ATX
SVT exhaust
SVT zip tube and air cleaner assembly
Tinted windows
17" Cougar Zn Wheels
#114000 02/15/02 12:20 AM
F
F
That's the same stuff that they use to coat turbine blades in jet engines! Keeps the metal from oxidizing at high temperatures.
FlyerST
1999 Tropic Green Contour SVT
Kenwood KDC-MP8017,4 Blaupunkt ODxa574 5X7,1 Infinity Basslink
#1602 of 2760
