#1515253 03/01/06 01:31 PM
9
95cgl Offline OP
9
Hi,
Does anyone know what year/model contour used same a/c accumulator as the 95 Contour GL 4.2l?
mine is rusted bad with holes and its starting to get quite warm in the middle of the day..
95 contour 2nd owner Miles: 98,800 Transmission: Automatic Engine: Zetec 4 Cylinder 2.0L Significant Problems: Wiring Harness (cracking!!)
#1515254 03/01/06 03:00 PM
9
95cgl Offline OP
9
lol me dumb.. not 4.2l 2.0L.
#1515255 03/01/06 03:55 PM
And why would you need to know what other models ran the same? Order one for you make and model.
#1515256 03/02/06 02:42 AM
9
95cgl Offline OP
9
because im gonna look at a junk yard.
#1515257 03/02/06 03:02 AM
E
E
http://www.trademotion.com/partlocator/index.cfm?action=getLocator&siteid=213787&chapter=DP2FM0&appSectionid=9&groupid=10000&subgroupid=60431&make=10&model=Contour&year=1998&catalogid=1
If you are going to start from your empty system you should get a new drier, vacuum the system and then recharge.
http://www.ackits.com/
Go to their forums and read up, ask questions there and you'll get a fast response.
#1515258 03/02/06 04:20 AM
9
95cgl Offline OP
9
Will do thanks
#1515259 03/02/06 12:46 PM
Reusing an old accumulator from a junkyard is not wise. Buy a new one.
Steve
#1515260 03/03/06 01:20 PM
9
95cgl Offline OP
9
Good News!
I bought one last night only 35 bucks (new of course)
i got the in-line filter for it to (2.99)
i have a old vacuum pump and ill get the r134a @ walmart only 9.99 vs. 12.99)
How many cans will it take does anyone know from past experiences?
oh i also bought the ford spring lock set (9.99)
is there any last warnings parts etc.. i need to know?
I hope to get this running ASAP.. how long do you guys think it will take?
( i haven't looked at it much) how will it come out? the bottom? III oh boy if this be the case i may be in trouble.. i have a small hand jack and a floor jack (forgot how tall) i ran into the same problem when i tried to change the head gasket
#1515261 03/03/06 05:59 PM
There should be a sticker under the hood with the R134a quantity. Be very careful that you don't overfill it.
#1515262 03/04/06 10:25 PM
9
95cgl Offline OP
9
Its Done!!!
Took about 2 hrs
dropped old out bottom checked to make sure was same, put it back in, made up my own 134a cables/meter checked registered at 10psi (wasn't empty when i took old off) ran vacuum for a few min. and filled.
Registered at a freezing 32.7!
!~Yahoo~!
