It won't do it while cold (below mid-gauge), but I've noticed tonight that my temp has risen at about the same time it started doing this. (it's about 3/4 on the gauge needle pointing straight at A on the *normal* word. It used to be at about M before...)
I'm sick & tired of that car. cost me about 4,600$ CA to get it running (stealership misdiagnosed a cracked head and had me replace about 2,200 in parts.)
So far,
-O2 sensor
-Timing Belt/Waterpump (the pump caused the engine to overheat)
-Battery (it was almost dead anyways)
-Plugs
-Air Bypass
I TOLD them to check the head/gasket, but no, it was fine until about a week later when it overheated in about 30 secs.
Had the engine/tranny replaced by a scrapyard.
(they wanted 3,000CA for a new head, those guys are crazy
I will have the supports checked, since it was done about 3 weeks ago, something might have come loose.
