Posts: 18 |
My Mondeo (same as '97 Contour) with the Zetec is down on performance. No missing, no check engine light or codes. I've replace the Catalytic converter, the front Oxygen sensor, have checked the operation of the EGR valve, changed the spark plugs and the Mass Airflow Sensor. I'm not expecting v8 performance here - but it is right slovenly off the mark - needs a lot of throttle movement to get any useful performance. Underway it goes fine - no missing etc but just seems 'flat' for performance when going up a small hill for example. There's nothing to indicate timing is off. The engine does not miss and will rev to redline (if you give it long enough!)
I'm thinking throttle position sensor may not be operating correctly - possible??
Malcolm
Ford Mondeo 1996 2.5L Duratec
12000 miles, auto, station wagon
Posts: 508 |
Yeah I was going to say go for the TPS first.
JD a.k.a Fingers
"Don't Panic"
'98 Contour GL 2.0L VCT ATX 88k
'98 Contour LX 2.5L MTX 120k
Street racing can kill
just less of a chance with a 2.0
CEG road warrior
CEG road warrior
Posts: 17,248 |
You'd know if the TPS was going bad. Idle would be on the high side.  The flat feel in performance is the Zetec.....plus I didn't see yours modded. Throw an intake on....that may liven her up a little.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 18 |
Any chance you have some 0-60 times and any other performance data for a stock zetec contour so I can compare?
Malcolm
Posts: 498 |
11-12 sec on a good day for me... im stock
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 5,143 |
Originally posted by ZetecGL: 11-12 sec on a good day for me... im stock
thats with an ATX, im really hoping this guy's has an MTX, especially in a mondeo, an ATX mondeo is disapointing in the performance department, how many kilometers do you have on it?
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 18 |
Only 45000 miles - yes it is an auto
Malcolm
Posts: 508 |
I would have to ask did it have performance that you now notice lacking?
JD a.k.a Fingers
"Don't Panic"
Posts: 21,653 |
Originally posted by AliasJerk: Originally posted by ZetecGL: 11-12 sec on a good day for me... im stock
Are you saying a mondeo is slower than a contour?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by SVTfrog: Originally posted by AliasJerk: Originally posted by ZetecGL: 11-12 sec on a good day for me... im stock
Hector
257HP/259TQ
160HP/141TQ
