Posts: 190 |
i did some searching on this and i plan to check the voltages as soon as I can get a jump. until then, i'm trying to figure out what else may be going on here.
i've been having issues with my battery being dead every time i go to start my car. with a jump the car will start and run indefinately. once the car is shut off, it will not restart due to the battery being dead.
couple of weird things i've noticed that may be contributing factors to why the battery is not charging...
-when i start moving from a dead stop, the whole electrical system "hiccups" at about 5-10 mph, resetting everything and almost stalling the car.
-once in a while, the motor and accessories will remain on after turning the ignition off and pulling out the key
at first i was going to replace the battery.
then i thought maybe the alternator wasn't charging the battery.
now i'm thinking it's more of a wiring problem.
my mechanic says he can't figure out what the problem is (scary right?)
I really want to avoid getting reamed by a dealer.
Former owner of a 1998 SF CSVT
Posts: 2,586 |
I had this happen to me 3 weeks ago. I changed the battery and everything was fine.
Did your mechanic check your alternator to see if it was "charging" the battery?
He thought that it would be alt that was messed up, but turned out to be just the battery.
97 T-Red LX ATX
pre98 CF SVT front,SVT rear/side skirts
FSVT wheels
Custom Front Ford Logo (body Colour)
35% tint all around with sun visor
WP With Metal Impeller?
Elky Grills
CTA Intake
CTA Custom Dual Exhaust
Posts: 5,143 |
Originally posted by SnafuFlux: I had this happen to me 3 weeks ago. I changed the battery and everything was fine.
Yeah man, it never hurts to try putting you're battery on a trickle charge. With my old battery some times it just would lose its charge, I knew I needed a new one but by charging it for a couple of hours once every couple of weeks I could live off of that battery for about 6 more months before I had to replace it.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 5,345 |
Charge the battery well. Then test battery and alternator.
Battery test. Engine off, headlights on for one minute. Voltage across battery terminals should be 12 to 12.5.
Alternator test. Engine running, voltage across battery terminals shold be 14 to 14.5.
1996 V6 ATX 96K miles
Posts: 55 |
Are you sure there is not a drain on the battery when the engine is not running, like some of you audio stuff? Pull the negitive bat. cable and connect a test light between the cable and the neg. bat Terminal, then start pulling fuses to see what is draining the battery. You should be able to replace the test light with a volt meter to see how much the drain is.
1998 Contour SE V6 MTX-75
Mostly Stock
1986 Ranger V6 4X4, the only mod: weight reduction by rust.
Posts: 699 |
Originally posted by 864X4: ... You should be able to replace the test light with a volt meter to see how much the drain is.
Ahem...current meter.
My Cars
1999 Silver Frost SVT - 80,000km #2603/2760 Aug. 10, 1999.
1996 Mercury Mystique LS V6 MTX - retired @ 323,151km.
1995 Ford Contour V6 MTX-sold @ 214,000km
Posts: 160 |
My neighbors taurus did something similar. The battery was always drained. Jumped it ran fine. Charged it. Didn't run. Jumped it, fine. Figured out some type of wiring problem with the airbag. But I not totally sure in your case.
96 Contour GL 2.0, ATX "Herman" 101K
"A Clean zetec is happy zetec"
Posts: 536 |
Originally posted by KyleH: Originally posted by 864X4: ... You should be able to replace the test light with a volt meter to see how much the drain is.
yeah you want to use an ammeter and it should be no more than about 100mA. if its any more than that you have a parasitic draw.
as for the battery voltage a fully charged battery should actually read about 12.65 volts.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 47 |
When you are doing the tests make sure that doors and trunk lid is closed and that the switch for the hood light is compressed. Otherwise you will show a false drain. I found this out the hard way. Turned out to be a damaged cable leading to the mega fuse.
Good Luck Dan
96 SE 2.5 V-6
89 Silverado 4 x 4 with snow plow no rust
