Posts: 18 |
I have been trying to locate an 88�°C (190�°F) thermostat for this vehicle - reason - when I replaced the thermostat in it recently, it was an 88�° version I took out, however the replacement was 92�°C (195�°F). When I fixed the problem with the car - which was actually a faulty temperature sending unit - I now find that the needle is running about 3/4 the way up the temperature gauge - sure wish I'd kept that old 88�° thermostat! Every parts provider I have tried stocks 195�° or 180�° (too cool) thermostats. Even at RockAuto the proper Motorcraft part RT1150 (ford no. F8RZ8575CA) says its a 190�°F version on the listing, but when I received this part, it is stamped 92�°C!! Anyone know where to go to get the 88degree version?
Malcolm
Ford Mondeo 1996 2.5L Duratec
12000 miles, auto, station wagon
Posts: 1,505 |
do you have a autozone or kragen there? they should have it.
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 5,143 |
Originally posted by contourfreak22: do you have a autozone or kragen there? they should have it.
autozone only carries at 180 degree. Check out Advance Auto, they sell a 190 Degree one. I use that for the winter and it sticks right in the middle of the gauge all of the time.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 13 |
Do know that the thermostat does not affect the final operation temperature just how long it takes to get there. So if you put a 160 degree thermostat in the engine will still operate at 190-210 degrees.
1999 Mercury Mystique LS Sport
2.0L Zetec
ATX
Posts: 5,345 |
Originally posted by Mystique99: Do know that the thermostat does not affect the final operation temperature just how long it takes to get there. So if you put a 160 degree thermostat in the engine will still operate at 190-210 degrees.
Ding, ding, ding, ding, ding! If you are having heating problems, the first thing to check is if the coolant strength is acceptable; buy a $5 coolant tester. Then you may want to consider flushing the system, testing the ECT sensor, Temperature gauge sender, radiator and water pump.
1996 V6 ATX 96K miles
Posts: 536 |
yup the lower temp thermostate will just open sooner allowing the coolant to flow and then cooling it off thus making it take longer for the enigne to reach operating temp. which as we know from a previous post that the engine wears the LEAST at operating temp. and the most when its cold
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 18 |
well, thanks for the tips. I ended up replacing the thermostat with a 180 degree version (82 deg C) and problem solved - temp gauge sits right where it should
Malcolm
