Posts: 67 |
Is there any alternative to the BAT adapter to fit a cone filter on my intake? It seems overpriced, and I've noticed dozens if not hundreds of MAF adapters on ebay for other cars selling for just a few dollars. I dont know if anyone here has ever tried to fabricate their own, but is it possible to buy one for a different car's intake and mod it to fit my Zetec?
Posts: 536 |
just buy a silicone coupler reducer and a small piece of tubeing and then attach the filter that way
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 21,653 |
Zetecs don't use MAF adapters. Filter goes right on the MAF.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 67 |
Easy enough. I just assumed, didn't even bother to look. Where can I relocate my intake air temp sensor to?
Posts: 261 |
drill a small hole in your tubing and squeeze it through and find a nut to go on the threads..and prolly some sort of sealant.
caleb d.
-Contour's dead, but is being revived...
Originally posted by CSVT1214: Originally posted by ford zetec2: after than, what do i do with the 98 short shifter? do I place it in there like it is?
Stick it in your butt and rotate.
Posts: 67 |
Drill a hole in the tubing between the MAF and throttle? That tubing is corrugated and I don't see how i can get a good seal with the ribs in the rubber. If I'm attaching a cone filter directly to the MAF, where else can i put it?
Posts: 536 |
im assuming then that you have a post-98 where the IAT is in the air box.
somebody that has done that will have to help you there. mines a pre98 with it in the tubing after the MAF
97 contour gl mtx
19mm bat sway bar
Posts: 67 |
Yea, it's a 2000. I'm thinking maybe I can drill a hole in the base of the air filter cone itself. Has anyone else on here tried something like this?
Posts: 21,653 |
I've heard of people doing that.
98.5 SVT
Posts: 2,483 |
Really shouldn't put the cone filte rright on the MAF. It should be atleast 6" (preferably 12" to 18" away). any less and a flow straightener (like the screen on the SVT MAF) should be used. While not necessary, it will help the computer react to airflow changes better, also provides for a smoother idle.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
