Hey guys,
I searched, but all I found was "car staying on with ignition off". This isn't my problem.
I had fuse #34 blown, (headliner lights not working, mirror, clock, etc..
I replaced the fuse about 15 minutes ago and now my ignition won't turn all the way off (to the point it 'clicks' and locks (right now I can still pull the key out but you could start the car with a screwdriver ,etc..) I took the fuse out and the igntion clicks a couple times then locks.. I put the fuse back in same thing.. I also notices I can shift it without the brake being depressed also.
Any help would be great.
