Page 2 of 2 1 2
#1504928 02/25/06 11:59 PM
Z
Z
Wow, yeah ford just swept up all the fillings on the ground and desided that would be a good source material for rods
It could have just been material fatigue, it is possible that you just had the crap luck of getting a rod that was slightly mis-produced and had some kind of structural defect but to last 8 years, its just wear and tear. I'm not sure what 118K km is in miles off the top of my head, but it sounds like a decent run.
It does sound like you're in a good position to do a 3L swap if you have the time. I know its not always the case and you need the vehicle on the road ASAP. But you did mention something about your 8 other cars So if you can I'd say go for the 3L swap.
1998 SE Duratec V6 ATX Ebay intake with K&N Filter Trubendz Exhaust Custom Hood
#1504929 02/27/06 05:58 PM
Originally posted by TourDeForce:
Originally posted by f365gt22:
I found out that yes indeed that it was a rod that broke. Another mechanic told me that Ford built the rods by forging metal filings together. Does this sound correct?
I believe he's talking about Powdered Metal, a process that uses pressure and heat to form complex metal parts with little or no machining. We use powder parts in our business, it's state of the art manufacturing.
If you're interested, here's a couple of links that discuss powdered metal connecting rods.
http://circletrack.com/nls/139_0311_connecting_rods/
http://www.metaldyne.com/metaldyne/sections/engine/prod_pmConnectingRod.aspx
#1504930 02/27/06 08:04 PM
I don't have this problem, but was wondering if only 01+ Taurus/Sable 3Ls go in 'contiques'?
Page 2 of 2 1 2
