I just bled my brakes. NO PROBLUM. THEN i bled the clutch with a mityvac brake bleeder. Now i have no clutch at all, brakes are working perfect. If i depress the clutch I can start my car but I can not get it to shift into gear. What did i do?
Midnight Red 95 Contour SE 5 speed, fully loaded. kkm M.A.F. adapter w/ K&N ru-3530, single Magnaflow muffler w/ no res. 2.25" custom catback exhaust, grafite painted stock 95 SE rims on bfgoodrich touring T/A's, 35% window tint around.
I ran into the same problem useing the Mityvac. Have someone slightly depress the clutch pedal about 2 inches. I used the power drivers seat to press a piece of wood against the clutch pedal, then I was able to bleed it, and get the firm pedal back.
