I have a 98 CSVT with about 79k miles on it. This past summer I did the LIM/UIM cleanin, cleaned the Tbody, MAF, IAC, replaced plugs, gaskets, etc. Car ran great for months. Recently had the cats replaced under warranty as well.
The car runs poorly at cold start and under moderate acceleration / lower rpms (under 3000-3500). It gets better the more the car is driven, say it runs better after 10 mintues than say after 5 mintues. Heres how it goes:
*cold start, starts OK runs fine for about 5 seconds at 1000rpm
*at about 5 seconds the idle drops, develops a very slight surge and idles very rough. Feels like it wants to stall but it never does. RPM hovers around 600rpm.
*runs like that for about 1 - 1.5 minutes and then the idle levels out and is much better. Normal idle is around 7-800rpm.
While driving:
*I need to take off at 1200-1500 rpms or the car hesitates and feels like it misses. Sort of feels like clutch slippage, but the rpms do NOT jump or rise suddenly. IT feels like a gear missing a tooth, best way to explain it.
*If I take off right and accelerate very slowly it does NOT do it
*Seems worse in 1-3rd gears
*Will do it in any gear if I try hard accel from under 3500rpm
*car feels fine and pulls great above 3500-4000rpm
* gas mileage has fallen to about 265 mile per tank from nearly 300 MPT in the summer. But that could be due to the winter blend gas and cold weather.
