Sounds silly, but you need to know if the amp is turning off, or if the woofer just stops playing while the amp is still on. If it does it when your sitting still, quickly check the amp to see if the power lights are still on. Then we can help narrow it down.
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
