Heres the deal, i have no fogs, interior lights, gauge illumination, but the radio works. I have replaced fuses 31, 34, and 5 with no luck. What in the hell fuse is it?
The "Bluer Tour" 1998.5 SVTour R.I.P. 2000 ATX Tour SE
Originally posted by CincySVT:
( we turn the switch the fog relay doesnt click, we jump the relay the fogs work, but flicker a little. Ok just as we think that we are getting somewhere the headlights randomly go off, and we cant get them to come back on, we tried everything, then we thoguht maybe it had something to do with the "fog light mod" I did awhile back , so we put that back the way it was stock , and still nothing at all. I ended up having to jump the relay for the lights in the engine bay fuse box to get home. We decided it must be the switch since when we jumped the fog light relay they worked, anyway I bought a new main headlight switch( 70 bucks) hooked everything back up and still nothing. Please help me out as I have no clue what the problem is, and cant drive at night with no headlights, another thing is the parking lights come on as they should, just not the headlights, PLEASEEEEE HELP ME < sorry for the long post but thought I should mention everything. Thanks
Griffin
Think this is a blown relay?
What other electricals work (don't work)? Headlamps, rearlamps, hazard lights?
For the 1996, the relays to check would be Relays 12 Courtesy light and 22 Fog lamp. Also check Fuses 5 Fog, 31 Instrument Panel and 34 Courtesy. Not sure about the 1998.5. Check your Owners' Manual.
my hi and low beams work, my horn works and so does the radio. My remote doesnt and nore do any interior lights. It does ding when i leave the key in the door.
What about exterior rear lamps and hazard lights? I am trying to determine if you have the headlamp switch issue or if it is some other issue. Note, that the foglights are usually not affected by the headlamp switch issue. And have you checked the relays yet?
Hazards. blinkers, do work. I have no idea where the relay for interior light is.
.. I have no idea where the relay for interior light is.
Do the external rear lights come on when when you turn on the headlights?
R12 is in the Power Distribution Box next to the battery.
yes they, i see the relay that you are talking about now. How should I go about replacing it. Is it just like a fuse?
What if relay D2 blew, the one for reverse voltage protecion, since this happened when i was hooking up a voltmeter. I do not think i crossed wire but it would make sense that something like that happened.
no my f'ing radio doesnt work! I am at wits end with this eletrical bull [censored]! SO where can I pick up this relay at?
Originally posted by SVTspazz:
... SO where can I pick up this relay at?
Ford dealer.
In addition, if your fuses are blowing one by one, you may want to have a look at this thread. You may have water going into your fuse box(es).
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1056473&page=&view=&sb=5&o=&fpart=all&vc=1
