#1502460 02/13/06 05:59 PM
blarrr Offline OP
96 4 cyl
Car seems to run fine when I first start it up.. smooth idle and shifts, but once it gets running for a bit and warms up to normal temp it has a tendency to surge at lights and stall out [particularly while my car is at an incline]. Any ideas? Replaced the maf and iac within the last month and put in new wires and plugs last week [bosch double plat/motorcraft wires].
Any CEL codes? Maybe vacuum leaks, Intake Air Temperature sensor, fuel pump, fuel filter.... It would help if you get a the PCM scanned and post the codes.
blarrr Offline OP
Only code is a p0420 that's been popping on/off for the past 6 months or so. Replaced the fuel filter about 2 weeks ago.
