#1501229 02/12/06 03:31 AM
1
1
I was doing the front wheel bearing and taking the steering knuckle off when I did the stupid act of trying to hit the shaft out of the hub with a hammer. Well i damaged a thread or two so I now need to replace my cv shaft.
Anyway...the shaft will not come out of the trans. Its stuck. I replaced a cv shaft on my cavalier and it pulled right out of the trans. Why is it stuck in there so good? I tried prying with a pry bar between the trans and shaft but still it doesn't budge. I am so confused at why its not coming out? please help.
Sometimes there a real bear, keep trying it will pop out.
95 GL SVT hybrid 02 Blazer xtreme 01 Aprilia SL1000 Falco
you want to do it with 2 people is the easiest....
one needs to use a pry bar and get constant pressure on it (a lot)...then the other needs to tap the side of the case where the bearings are with a hammer.
it'll pop right out...the ket is the keep pressure on the circlip and then with a couple knocks they pop out.
98 E0 SVT with some stuff
E
E
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/d4/65/0900823d801bd465.jsp
Just showing you the proper way it should be removed, with a slide hammer. Autozone might even have one to rent.
even a slide hammer doesn't do that great of job...trust me I battled with mine for like 6 hrs one time...broke chains and everything...called a mechanic that my father-in-law knew and he said put pressure on it with a pry bar and they use an impact hammer, but he said a normal one would work.
My father in law tapped (and I mean tapped) on it and it popped out so fast it knocked me one my butt quite hard.
1
1
OK, well while pulling on it and trying to pry it out, the outer piece seperated from the inner piece. So now i only have that little stub coming out of the trans. You say the trick is to keep pressure on it with the prybar while someone else hits it with a hammer from the side?
E
E
I have an OTC brand slide hammer and the special C shaped attachment and it works fine for me.
yep...
