#14979 05/10/02 07:25 PM
N
N
I want to paint my front oval grill black to match the rest of the car...to anybody who has already done this what steps did you do? Ive never done any painting before, but Im thinking
1. sand it down
2. use an automotive primer?
3. actual paint
4. few coats of clearcoat
does that sound alright? anything I'm missing?
1999 Black SVT/5% Tint/Bassani/Konis/Eibachs
1965 Ford Mustang Fastback/In Progress
#14980 05/10/02 07:55 PM
I have never painted the grille, but I do work in a paint shop. Here's what I would do, but get a second opinion from someone who has painted this particular part before...
1. Mask off areas you don't want painted/primed.
2. Sand. Since the part is chrome finished, I would use a coarse paper like 60 to 80 grit on a DA (if at all possible). You might even use up to 240 grit for this.
3. Spray primer in even coat over grille. DO NOT load the primer on. If you put too much product on in one coat it will never dry and it will ruin your final paint job.
4. When finish is 'eggshell' texture, spray another light coat. Continue this proceedure until scratches are no longer visible through primer.
5. Cure in direct sunlight. Press your fingernail into the primer (LIGHTLY) if you think it's dry. There shouldn't be a mark.
6. WET sand with 600-800 grit paper until finish is ice-smooth. Keep water continuously on surface.
7. Spray paint over primer. Try using one good coat without running it. Repeat if you need to. Just be very patient!
8. Almost immediately spray the clear coat. PAY ATTENTION not to run this product!
9. Bake the grille in sunlight for a few hours.
10. NEXT DAY, wet sand dirt and debris out of the clear coat using 1500 to 2500 grit paper and a soft touch. Careful not to sand through clear coat.
11. Buff with a variable speed buffer @ 1500 RPM, until mirror-finish.
That's how we do it on BMWs, Mercedes, and Lexus'. That's how I'd do it on my own car. Use the most expensive stuff you can buy and be very patient. GOOD LUCK! wink
1998 Contour Sport V6, Black
*Cold air induction
*Powdercoated intake manifold (more powdercoating coming soon)
*Blue headlights, foggies, and signals (no reflectors)
*CEG stickers & removed door moldings
1994 Ford Aspire 4-door, looks like a big egg
*64 hp 4-cyl
*5 speed
*"13 steel rims with go-cart tires
*74 mph top speed
*I'm going to auto-x the thing (but not compete)
#14981 05/10/02 08:39 PM
N
N
thats exaclty what i was looking for, an expert opinion. I'll give it a shot, hopefully I wont mess it up too much, THanks for the help.
