N
N
How do i go about removing the fuel injector o-rings without hurting anything? just cut em?
2000 Black SVT Contour
Ummm, why would you cut them? Just roll them off.
Best method I have found is to grip the injector in one hand, pinch/push the o-ring with thumb and forefinger to create a bulge in the o-ring. Use the thumb on the non holding hand and roll the bulged portion of the o-ring up and out of the retaining groove.
I use a bit of vasoline to lube up the o-ring when replacing, not a gob just a smear. Keeps it from pinching/galling when installing. Be certain you seat the injectors fully.
jkr2wld '97 LX 2.5 ATX Vibrant White
