#1500340 02/10/06 02:02 PM
9
i run a test and got these codes is it a part that needs cleaning or does it need to be replaced. i know the o2 sensers have to be replaced. but what about these.551 Problem in Intake Manifold Runner Control (IMRC) solenoid/circuit.327 (O,R,M) EGR feedback signal is/was low. thanks for any help with this. just bought it for my wife.
#1500341 02/10/06 02:56 PM
For 327, check for loose or chafed or broken wires to the Differential Pressure Feedback EGR (especially at the connectors) or to the PCM.
Picture from Chongo for the DPFE.
Originally posted by chongo:
Did someone call me out.......LOL
here you go.
#1500342 02/10/06 03:06 PM
For the 551 code, check the IMRC solenoid to make sure it is not unplugged. Check the solenoid coil for proper resistance (50-100) ohms. If it's plugged in and the solenoid coil tests good, then you either have a wiring harness or PCM fault. The IMRC solenoid is on the firewall side of the engine next to the EVR solenoid,
The 327 is very likely the EGRP (Dpfe) sensor. There are a few other causes so additional diagnostics should be performed to prevent unnecessary parts replacement. Refer to the PC/ED for exact procedures.
Steve
#1500343 02/10/06 04:47 PM
2
Both my 95s have vacuum operated IMRC. Did they put the electronic box on late in the year? Mine were built March 95.
#1500344 02/10/06 06:17 PM
I know the electronic boxes showed up in the 96-on vehicles. Don't know if any 95s got them.
Steve
#1500345 02/10/06 06:31 PM
2
When mine was broken - right after Ford replaced the wiring harness, it didn't pop a code. There is no sensor or switch to tell the EEC it is, or isn't working. When the vacuum drops the runners pop open. Vacuum holds them shut.
#1500346 02/11/06 05:15 AM
9
i check all the wires to the senser and it is plugged in good . where is the vac line that you are talking about.
#1500347 02/11/06 02:53 PM
The 551 code is an electrical problem, not vacuum related. The computer tested the solenoid coil and it failed.
Test the solenoid. I already gave you the measurement to be expected.
Steve
